TwinTurbo.NET: Nissan 300ZX forum - Re: the defi is tapped in between the cluster and the ECU?
Subject Re: the defi is tapped in between the cluster and the ECU?
Posted by Carlos Ramirez on November 14, 2012 at 12:17 PM
  This message has been viewed 180 times.
In Reply To the defi is tapped in between the cluster and the ECU? posted by aliaZ on November 14, 2012 at 12:11 PM
Message I was going to check at the ecu first and remove and VSS taps and do a continuinity check as well. Just was kind of hoping to hear yeah "I had that problem before and the cause was etc and the fix was etc".
Thanks for you feedback.
