TwinTurbo.NET: Nissan 300ZX forum - the defi is tapped in between the cluster and the ECU?
Subject the defi is tapped in between the cluster and the ECU?
Posted by aliaZ on November 14, 2012 at 12:11 PM
In Reply To ECU not seeing Vehicle Speed posted by Carlos Ramirez on November 14, 2012 at 11:12 AM
Message I'd try disconnecting the defi and see if that fixes your issue. If it does, the defi is corrupting the signal before it reaches the ecu. If it still doesn't work, then look for a connection fault between the defi and the ECU connection.
