TwinTurbo.NET: Nissan 300ZX forum - Re: TDC Help!!
Subject Re: TDC Help!!
Posted by Cjw3 on November 13, 2012 at 10:15 PM
In Reply To TDC Help!! posted by Toddjr1034th on November 13, 2012 at 09:48 PM
Message Presume you mean the Cam Drive Sprocket, that is on the Crank?.. The Dot on the Can Drive Sprocket will line up to the Divot on the oil pump housing Drivers side of the Motor.. Unless you put the lower Drive Sprocket on Backwards.. then you cant see the Dot.. and gotta turn it around..
Photobucket is being stupid for me right now.. cant get on to get a pic.. but here is my Nissan Library Link.. Might be something there you can use.. if you can get on..
[ http://s312.beta.photobucket.com/user/CapWeir/library/Nissan%20Shots ]
Cj
