TwinTurbo.NET: Nissan 300ZX forum - Compression Check
Subject Compression Check
Posted by Cjw3 on November 10, 2012 at 10:33 PM
  This message has been viewed 150 times.
In Reply To Re: I think there's 4 things that might be throwing timing off posted by tangeray on November 10, 2012 at 08:34 PM
Message Do a compression Check to see if you nicked few Valves.. As it's not usually possible to blow a belt, and Not hit some valves..
Are you sure the Timing is being checked properly? Have you checked the Timing on this car with the Same Timing Light Before?.. Others have had troubles getting a Light hooked up Properly..
My thoughts are, the Timing is proper.. somehow you are hooking up the Light Improperly, and the Valves are bent ..
Lets hope I'm wrong..
Cj
