TwinTurbo.NET: Nissan 300ZX forum - Problem solved!!!
Subject Problem solved!!!
Posted by DE944 on November 08, 2012 at 10:12 AM
  This message has been viewed 146 times.
In Reply To need input for an overheating problem posted by DE944 on November 07, 2012 at 10:58 AM
Message I replaced the radiator cap with a new one and voila, problem solved. The cap worked fine under pressure, but would not hold a vacuum. As the radiator cooled and created a vacuum, the rad cap was allowing it to just bleed off. Checked my cold water level this morning and the radiator is full again and the overflow tanks water level has dropped to a level equivalent to the water replaced in the radiator.
