TwinTurbo.NET: Nissan 300ZX forum - the timing would be far too advanced
Subject the timing would be far too advanced
Posted by aliaZ on November 08, 2012 at 9:07 AM
  This message has been viewed 139 times.
In Reply To Hypothetical tuning question: posted by Zvil (FL) on November 07, 2012 at 07:42 PM
Message If you average the MAF inputs instead of adding, the ECU will think you are under lower loader conditions than actual, and would be accessing a far more aggressive area of the timing map.
Also, for the same reason, you'd be in the wrong area of the fuel map as well and would likely be lean.
In short...you'd blow your engine...
