TwinTurbo.NET: Nissan 300ZX forum - Bad alternator?
Subject Bad alternator?
Posted by kay8888 on November 07, 2012 at 7:31 PM
  This message has been viewed 366 times.
Message I got a rebuilt alternator for the Zed a month ago and got it installed by a mechanic. What is happening now is that the dash lights are pretty dim when i start the car but when i rev, they get brighter. I checked the battery voltage before starting the car and it measured 12.7 volts. When i started the car, i got 12.2 volts. When i put load on the car, it gave me 11.8 volts.
After i rev the car and the dash lights got brighter, i checked the voltage with the accessories on and it gave me 14.9 volts and when I turned the accessories off, it gave me 15.2 volts.
What would cause the dash lights to be so dim when i start the car and go brighter once i rev? I have searched quite a bit and found a few possible solutions. The alternator belt could be loose. The voltage regulator on the new alternator could be bad or I might have a bad/loose ground somewhere.
Can somebody help me as to what might cause this? I am not that good with the electrical things. Thanks
