TwinTurbo.NET: Nissan 300ZX forum - some additional clarification
DE944
on November 07, 2012 at 4:23 PM
need input for an overheating problem
posted by DE944
on November 07, 2012 at 10:58 AM
The car is not overheating at this time. The temp runs right in the middle of the temp gauge just like it always has. I just have to watch the water level because the radiator does not pull back from the overflow tank.
DE944
10:58:25 11/07/12
make sure your coolant return line isn't kinked
Zvil (FL)
11:35:14 11/07/12
no lines kinked, plenum water lines deleted. no leaks. (n/m)
DE944
12:49:54 11/07/12
Are you 100% sure the system is bled properly? (n/m)
Summeronthechain (MN)
13:05:06 11/07/12
yep, 100% sure. (n/m)
DE944
13:50:51 11/07/12
you dont see any signs of leaks?
300ZMang
13:50:53 11/07/12
newer water pump, system holds 16psi w/no leaks (n/m)
DE944
13:52:31 11/07/12
I once had a radiator that did not seal with the cap.
zellamay
14:47:00 11/07/12
Never mind, if it holds 16 psi, then this isn't it. Have
zellamay
14:53:36 11/07/12
some additional clarification -
DE944
16:23:43 11/07/12
Re: need input for an overheating problem
MaxxAction
18:14:53 11/07/12
Wally_562
19:25:00 11/07/12
Re: Re: need input for an overheating problem
Medallion Man
03:49:39 11/08/12
MaxxAction
08:25:13 11/08/12
Problem solved!!!
DE944
10:12:39 11/08/12
best case scenario... :) nice one.. (n/m)
Medallion Man
10:17:12 11/08/12
Re: Problem solved!!!
MaxxAction
10:27:51 11/08/12
