TwinTurbo.NET: Nissan 300ZX forum - make sure your coolant return line isn't kinked
Subject make sure your coolant return line isn't kinked
Posted by Zvil (FL) on November 07, 2012 at 11:35 AM
  This message has been viewed 148 times.
In Reply To need input for an overheating problem posted by DE944 on November 07, 2012 at 10:58 AM
Message make sure it is sitting loose and undisturbed in any way. Check to make sure it doesn't have any pin holes and that the clamp that holds it to the radiator is air tight.
If you haven't already: you should delete/replace (with silicone hoses) the coolant lines under the intake plenum.
I once had a leak that was so slow I couldn't see any signs of it leaking except an occasional whisp of steam AFTER I turned the engine off.
If the replacement cap is also used already, it would be a good idea to get one that is OEM quality not the Autozone crappy sort of works replacement.
If you love your Z it'll love you back.
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
