TwinTurbo.NET: Nissan 300ZX forum - is your idle switch on? Is your idle speed correct?
aliaZ
on November 05, 2012 at 5:28 PM
PTU vs Coil Pack Timing
posted by alpha_omega16
on November 04, 2012 at 09:31 PM
Also, don't set your timing to what is shown using your ECU monitoring program. They aren't necessarily supposed to match because the ECU will change the timing as needed based on engine speed and load requirements
alpha_omega16
21:31:46 11/04/12
Commonly known.
Woody75 (Denver)
22:13:49 11/04/12
I will give it a shot tomorrow..
alpha_omega16
22:44:32 11/04/12
Auto ecu is going to show higher timing. 20 I believe. (n/m)
Woody75 (Denver)
09:19:06 11/05/12
Re: PTU vs Coil Pack Timing
craigz96tt
10:45:05 11/05/12
is your idle switch on? Is your idle speed correct? -
aliaZ
17:28:37 11/05/12
Yes, the idle switch is on and functioning correctly.
alpha_omega16
11:33:40 11/06/12
The ECU expects 15 degrees, not 20
aliaZ
23:29:18 11/07/12
Agreed... timing light is the only way!! (n/m)
Medallion Man
10:41:26 11/08/12
