TwinTurbo.NET: Nissan 300ZX forum - Re: PTU vs Coil Pack Timing
Subject Re: PTU vs Coil Pack Timing
Posted by craigz96tt on November 05, 2012 at 10:45 AM
  This message has been viewed 192 times.
In Reply To PTU vs Coil Pack Timing posted by alpha_omega16 on November 04, 2012 at 09:31 PM
Message I believe the only sure way to adjust or check timing if you don't have the Nissan adapter is to use a common plug wire with the #1 coil removed then you have to compensate if you have under drive pulleys with a different view angle
