TwinTurbo.NET: Nissan 300ZX forum - I think I want to use my current setup unless it's bad >
Subject I think I want to use my current setup unless it's bad >
Posted by Zvil (FL) on November 05, 2012 at 8:40 AM
  This message has been viewed 231 times.
In Reply To Use a TT ecu, TT EFI @ TT fuel pump & controller (n/m) posted by Bernie (NoVA) on November 05, 2012 at 02:01 AM
Message I'm not trying to give you a hard time, I'm just learning- I don't think I can find the answer to this question by searching.
I currently have a chipped 8 bit N/A to TT ecu running 370 injectors, I have the TT fuel pump installed in my tank. (I'm going to give this ecu to my buddy with the hodgepodged TT motor setup I traded him) I have another N/A 8 bit ecu that I want to chip for N/A to TT and 740 injectors. Is there a big difference/benefit in using the TT ecu and fuel controller instead? will it hurt or limit anything with the way I have it now?
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
