TwinTurbo.NET: Nissan 300ZX forum - PTU vs Coil Pack Timing
Subject PTU vs Coil Pack Timing
Posted by alpha_omega16 on November 04, 2012 at 9:31 PM
  This message has been viewed 297 times.
Message Today when setting the timing I Noticed that the PTU and Coil pack readings were not the same.
While using an ECU monitoring Program, I set the timing to the value shown, in this case 20*.
Decided to check the reading at the PTU Loop as well, and found the PTU was showing 10* more than the coil pack.
Has anyone else ever had this problem and/or know how to repair it?
My understanding is both locations should be the same.
Also, noticed the timing when read from the ECU would never drop to 15*.
TPS = 0.46V
Coolant Temp = 190*F
Thanks,
Jason
