TwinTurbo.NET: Nissan 300ZX forum - No shorts in the wiring as far as I can tell
Subject No shorts in the wiring as far as I can tell
Posted by Jayru on November 04, 2012 at 9:34 AM
  This message has been viewed 220 times.
In Reply To Re: Headlight relay clicking/draining the battery. posted by Medallion Man on November 02, 2012 at 11:49 AM
Message But something funky is going on with the brights switch. When you pull in to flash the brights they stay on unless you then push the switch forward to the on postition and pull it back off again. Do the brights work through the same relay in the engine compartment as the low beams?
93 2+2 Twin Turbo Track Build - jsworks.org for more info!
