TwinTurbo.NET: Nissan 300ZX forum - Was the Det sensor bypassed? If your getting a code 55 then
Subject Was the Det sensor bypassed? If your getting a code 55 then
Posted by Drunkpunk082 on November 03, 2012 at 11:48 AM
  This message has been viewed 257 times.
In Reply To Re: Code 34 is det sensor, plugging your vtc back in correctly posted by kay8888 on November 02, 2012 at 09:38 AM
Message the ECU thinks everything is good. I've seen people wire in a resistor near the ECU and cut the plug under the hood. Look for any electrical tape or modification near the ECU plug. Do you have safety boost? Honestly if all is good and you have no safety boost then I wouldn't worry. Those Det sensors are nothing but trouble anyway. Just leave it be and run high octane gas and you should have no issue. Don't fix what isn't broke!
