TwinTurbo.NET: Nissan 300ZX forum - are they leaking the silicone fluid?
Subject are they leaking the silicone fluid?
Posted by Shiers69 on November 01, 2012 at 11:23 AM
  This message has been viewed 157 times.
In Reply To Can worn subframe/rear suspension bushings cause vibrations? posted by Jayru on October 30, 2012 at 09:34 PM
Message You can replace with solid, Energy Suspension, or those new Whiteline ones which are supposedly similar to OEM. If you're that crazy about vibration, you should probably avoid the solid or ES bushings and go with the whiteline ones.
Also, replacing these is not a fun job - just so you're aware.
