TwinTurbo.NET: Nissan 300ZX forum - well... searching will help but I have some input anyway
Subject well... searching will help but I have some input anyway
Posted by Zvil (FL) on October 31, 2012 at 9:08 PM
  This message has been viewed 180 times.
In Reply To subframe swap? posted by renshi on October 31, 2012 at 01:04 PM
Message I have a NA to TT Z and I kept the N/A rear end. I put down faster 1/4 times than 2 of my other friends with Z32's that have more power than mine, it might be because of my driving skills or it might be because of the differential? at the same time I commute with my Z 100 miles per day and my cruising rpm is 3100+ at 75mph- I know I could be getting better gas mileage if I had a TT rear end. I also feel that 1st gear is useless because it will just spin the tires like crazy. You can totally come test drive mine and see how you like it. The TT rear end supposedly is thicker and able to withstand higher horsepower (maybe 600+) but that would only come into effect if you ran true drag slicks because tire spin isn't what breaks rear ends it's all about HIGH torque combined with HIGH traction. If you are interested in a N/A rear setup I would be more than happy to trade one of my subframes and differential sets (as I have 3 N/A rear ends) for a TT one straight up installed.
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
