TwinTurbo.NET: Nissan 300ZX forum - Little bit is normal, do you have PCV valves installed still
Subject Little bit is normal, do you have PCV valves installed still
Posted by Drunkpunk082 on October 30, 2012 at 1:57 AM
  This message has been viewed 222 times.
In Reply To oil in intake plenum and intake piping posted by 1995z32tt on October 28, 2012 at 10:42 AM
Message Its real common for a little to leak into the intake plenum on hard cornering if you have a PCV system. You can remedy this by installing a catch can. From the sound of the condition of your motor I would say that it is likely something else, turbos or blow-by. But PCV's can cause oil buildup in the intake also. I have a very tight engine with new turbos and I have enough in my plenum from the PCV's that I can hear it bubbling when the car is hot and I turn it off. Little bit of brake cleaner can clean that up, or pulling the plenum and running it through a parts washer does wonders also. I would clean it up and see if it comes back after some EASY driving.
