TwinTurbo.NET: Nissan 300ZX forum - Remove the fuel pump fuse located in the fuse box in front
Zvil
on October 29, 2012 at 6:42 PM
release fuel pressure
posted by BOB2506
on October 29, 2012 at 04:54 PM
of the battery then crank the engine till it doesn't start and a few times more after that then remove the gas cap to relieve back pressure as 1911a1 said
BOB2506
16:54:30 10/29/12
Open the gas cap to relieve the pressure. (n/m)
1911a1
17:02:41 10/29/12
You were not misleading. The answer you got is correct.
zellamay
17:41:11 10/29/12
Remove the fuel pump fuse located in the fuse box in front -
Zvil
18:42:26 10/29/12
+1 This is the correct method.
Drunkpunk082
01:42:03 10/30/12
I've used this method before. It works.
baggar11
16:57:10 10/30/12
Yeah honestly I normally pull the fuze so I don't have to
Drunkpunk082
20:18:06 10/30/12
