TwinTurbo.NET: Nissan 300ZX forum - Re: summer no hard feeling
Subject Re: summer no hard feeling
Posted by Medallion Man on October 28, 2012 at 4:05 AM
  This message has been viewed 126 times.
In Reply To summer no hard feeling posted by bizaws on October 27, 2012 at 05:15 PM
Message Hi,
I understand your dislike of forums but it helps to provide important information first up, there is no way Summer could have known you used a timing light since the timing can bee seen on software (e.g. conzult) your post gave no indication of your ability or knowledge.
So listing the things you have checked would also help. :)
Just saying "everything" is a little ambiguous.
So we can assume you have checked the tps voltage?
Recalibrated the Throttle body linkages?
All connectors checked and clean (inc battery & ecu/s)?
All earths checked and or earthing kit?
you have checked spark on each coil packs and plugs?
you have checked injector are working and for leaks?
but it really sounds to me like the timing could be out or have slipped a cog.
Yeas I know you say all marks are correct… BUT
You don’t say when this started to happen or if it been like it since the build or after one of the tunes?
Is the timing belt OEM? After market ones are notorious for having the markings a little wrong.
I know it’s a crap job to do but you might want to check the belt again and count the cogs.
Best of luck…
