TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Sounds like multiple issues.
Subject Re: Re: Sounds like multiple issues.
Posted by Medallion Man on October 28, 2012 at 3:38 AM
  This message has been viewed 125 times.
In Reply To Re: Sounds like multiple issues. posted by Wally_562 on October 27, 2012 at 12:34 PM
Message fuel related issues could be:
fuel pump (in the tank)
fuel ecu (beside rear seat)
fuel relay (foot well)
fuel filter
fuel pressure regulators
fuel line (under plenum)
injectors
CAS
and worth checking the fuel pump fuse for corrosion (engine bay fuse box near bulk head)
So as has already been advised, more information about the car is important and checking/cleaning all electrical connectors (including the battery).
also as has been advised fuel pressure check should be able to rule out a few of those.
Ideally you want to seeing what the fuel pressure is doing when you are having the problem.
what work have you had done recently?
what have you done to diagnose / fix it?
