TwinTurbo.NET: Nissan 300ZX forum - summer no hard feeling
Subject summer no hard feeling
Posted by bizaws on October 27, 2012 at 5:15 PM
  This message has been viewed 136 times.
In Reply To Good luck with your problem. (n/m) posted by Summeronthechain (MN) on October 27, 2012 at 03:13 PM
Message I just hate posting to forums because people talk to you as if your an idiot. I built the car myself and im having this issue. Its not related to tune because its a fresh tune from jim wolf tech about 2 weeks ago had a czp tune before. The injectors ohm out around 11.2-11.8 on all. Ptu is the new one and it work im getting spark. I dont have any boost/vac leaks that i can find, the intake is dual with selin translator and yes the ecu is tuned for this. Timing on all cam gears and crank line up so its not this either. The fuel pressure is at 38 psi at idle and rises to about 55 under wot. I have no emission system, egr, cats, or the canisters in fenders nor carb canister. Im lost and need some real and valuable advice please.
