TwinTurbo.NET: Nissan 300ZX forum - For what you are describing - leak is external to the
Subject For what you are describing - leak is external to the
Posted by jzack on October 27, 2012 at 7:56 AM
  This message has been viewed 199 times.
In Reply To Combustion Leak Tester posted by pieboy100 on October 27, 2012 at 12:04 AM
Message engine (not an HG). What about the water pump weap hole? Dripping down from there? Or the upper radiator hose - which is the hose that usually goes bad due to engine movement (fyi: I had a new 1yr old upper hose do this). Also possible the radiator has a pin hole leak but kind of doubting that -- since it should be a easy to spot....
However - not to say there isn't another issue too but find this one first.
