TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Fuel only going to one bank at a time
Subject Re: Re: Fuel only going to one bank at a time
Posted by Zinister1 on October 26, 2012 at 10:02 AM
  This message has been viewed 130 times.
In Reply To Re: Fuel only going to one bank at a time posted by Medallion Man on October 26, 2012 at 02:05 AM
Message I ran into a similar problem, injector clicked and everything checked out, injectors were even new and new style. Ended up swapping out the injector in the problem cylinder to a good working cylinder, the problem then lied in the new cylinder.
So I sent back the injector to get replaced, it tested out fine, flow test, ohm test, everything. He ended up sending me a new injector, problem solved. There could be an internal problem with injector, try swapping them and see what happens. Its how I found my problem.
