TwinTurbo.NET: Nissan 300ZX forum - Re: Misfiring under boost.
Subject Re: Misfiring under boost.
Posted by scottmt21 on October 25, 2012 at 6:04 PM
  This message has been viewed 285 times.
In Reply To Misfiring under boost. posted by AsaHerring on October 24, 2012 at 05:50 PM
Message I have seen a Z that would misfire and POP around only under boost and mostly at higher boost levels that turned out to be a couple of bad coil packs! the car would idle and drive great until the boost got over about 16 psi. (higher load on the coil packs) If everything else checks out you might try swapping the coil packs with a known good set. ;-)
