TwinTurbo.NET: Nissan 300ZX forum - causes of high nox: & egr flow test
Subject causes of high nox: & egr flow test
Posted by Dane (Houston) on October 25, 2012 at 1:40 PM
  This message has been viewed 279 times.
In Reply To failed....again.. posted by RonDeezy on October 22, 2012 at 06:24 PM
Message Low EGR flow
inefficient cats
lean air fuel ratio
over advanced ignition timing
Egr flow test:
install vac gauge to manifold pressure
hold engine at 2000-2500rpm
apply vacuum to egr (via borrow dampener vac signal or and pump)
expect to see manifold vacuum decrease 4 inchs/psi of vac
if there is no decrease tubes are clogged or valve is bad.
if all above works, Test that the EGR vacuum control solenoid works.
Houston Z
www.houston-nissans.com
