TwinTurbo.NET: Nissan 300ZX forum - Coolant leak
Subject Coolant leak
Posted by March.Prince on October 24, 2012 at 3:32 PM
  This message has been viewed 152 times.
Message 1990 300zx N/A
So this happend a while back, but i just parked the Z and havent been back in the engine bay to really check it out much. well today i decided to investigate. i started the car, everything as normal. Let it idle, no leaks, no smells while cold.
As soon as it starts to get warm, i can smell coolant, so i start searching for where its coming from. scanning from the rear hoses, to the front.... Its in the front, but i cant pinpoint it. it leaves a puddle under the car pretty fast, and its getting all over the front water pump, and other various parts up there.
I found a post that seems to point in the direction i need to go in, but i just wanted to check with you guys and see if you had any input.
the post.
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=817150&forum=technical&dtSearch=36 ]
