TwinTurbo.NET: Nissan 300ZX forum - my NA Z failed nox a lot too, like 10 times..still hasn't
Subject my NA Z failed nox a lot too, like 10 times..still hasn't
Posted by inf on October 23, 2012 at 12:45 AM
  This message has been viewed 305 times.
In Reply To failed....again.. posted by RonDeezy on October 22, 2012 at 06:24 PM
Message passed. I did everything under the sun. The first time it failed like yours...
after I suspected it was the cats making it fail I welded on new Magnaflow's...
well after testing it the nox shot up to 1500+ppm.
I then proceeded to clean the EGR pipes as well as test the solenoid and valve. Everything checked out, but the pipes were super clogged. I cleaned the pipes and it still was 1000-3000ppm!
I've deduced the reasoning as this...the first time I tested it with stock cats there was still super clogged EGR pipes. The second time with new cats the welds had holes before the cats. So if I just cleaned the pipes instead of getting new cats it'd probably have passed.
Now the thing has valve guide seal issues and I haven't had time to retest after sealing the pinhole leaks (3 of them on the side they were testing). I'm hoping my assumptions are correct.
