TwinTurbo.NET: Nissan 300ZX forum - i didnt mean a ton of sunlight.
RonDeezy
on October 23, 2012 at 12:09 AM
I'm not an emissions pro but..
posted by Drunkpunk082
on October 22, 2012 at 11:42 PM
just that i could see through them as in im pretty sure theyre not plugged up.
i saw the vacuum trick you mentioned.but i cant remember if it was to lower the nox.
failed....again..
RonDeezy
18:24:22 10/22/12
Re: failed....again..
Cjw3
21:35:49 10/22/12
i have a feeling it could be my timing.
RonDeezy
21:56:18 10/22/12
Re: i have a feeling it could be my timing.
Cjw3
22:51:35 10/22/12
i set to 15 degrees.
RonDeezy
23:33:33 10/22/12
If you still have the EGR system there is 99.9% chance
njz
05:55:40 10/23/12
Drunkpunk082
23:42:27 10/22/12
i didnt mean a ton of sunlight. -
RonDeezy
00:09:03 10/23/12
I'm not 100% sure what it effects...
Drunkpunk082
01:25:09 10/23/12
Re: I'm not 100% sure what it effects...
baggar11
13:49:28 10/23/12
my NA Z failed nox a lot too, like 10 times..still hasn't
inf
00:45:11 10/23/12
jeez man.good look with your smog adventure.ha
RonDeezy
01:38:19 10/23/12
just took a look at my passenger side vacuum lines
RonDeezy
04:11:08 10/23/12
$70.00 each Magnaflow Cats? (n/m)
njz
14:04:27 10/23/12
causes of high nox: & egr flow test
Dane (Houston)
13:40:52 10/25/12
thanks dane.
RonDeezy
01:04:02 10/26/12
