TwinTurbo.NET: Nissan 300ZX forum - Re: failed....again..
Subject Re: failed....again..
Posted by Cjw3 on October 22, 2012 at 9:35 PM
  This message has been viewed 212 times.
In Reply To failed....again.. posted by RonDeezy on October 22, 2012 at 06:24 PM
Message HC's look excellent, and C0 is good.. the Free Oxygen (O2%) is also low.. I'd say the Cat is working fine..
NOx will likely be from higher than normal combustion Temps.. Either the EGR is not Opening, ( This slows down the Burn rate reducing Combustion Temps ) OR the Timing is too advanced, causing a Quick Burn rate..
Check the Ignition Timing, see where it is... if it is proper, then pull a vacuum on the EGR Diaphragm and see if the Car Stumbles at Idle.. it should
If it does stumble, when you pull a Vacuum on the EGR Diaphragm, then it's LIKELY an EGR Control Problem ( Vacuum Hose Routing ).. if it Does NOT stumble when you pull a Vacuum on the EGR Diaphragm, then you have a Plugged or Non Functioning EGR Valve.
Cj
