TwinTurbo.NET: Nissan 300ZX forum - PTU drives the coil packs - get's it firing signal from
Subject PTU drives the coil packs - get's it firing signal from
Posted by jzack on October 22, 2012 at 7:26 PM
  This message has been viewed 203 times.
In Reply To Re: Did things work well before the harness swap? If so, posted by ZTom on October 22, 2012 at 07:15 PM
Message the ECU. Injectors wire directly to the ECU.
Does sound is if other things may be going on here too? But you are on the right track - break the problem down and solve in piece parts. Since #1 doesn't have spark - would suggest you get that solved first....
