TwinTurbo.NET: Nissan 300ZX forum - Re: Steelies From Sentra SER will fit on '95 N/A?
Subject Re: Steelies From Sentra SER will fit on '95 N/A?
Posted by gbhrps on October 22, 2012 at 3:33 PM
  This message has been viewed 248 times.
In Reply To Steelies From Sentra SER will fit on '95 N/A? posted by Sustain26 on October 22, 2012 at 08:34 AM
Message I can't verify if those Sentra rims will be correct for your Z32, but I can tell you that you need to be sure that you don't mount a snow tire that is wider than the Sentra rim is supposed to have, 6 , 6.5 or 7 inches, whatever.
You don't need to run a 225 width, as a narrower tread will be better in the snow, as it'll cut into the snow pack, rather than aqua plane up on top of it.
My experience with snow tires on three Subaru Outbacks has taught me that even though my summer tires are 225's, going the same width with a snow tire is disasterous at speed. You end up all over the road, and this is on an all wheel drive car.
I've learned to drop down to 205's in winter tires, and its like being crazy glued to the road. One look at the ralleye car tire width during winter races will show you the same thing. Good Luck!
