TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Would that not be from oil being sucked up by the PCV
Subject Re: Re: Would that not be from oil being sucked up by the PCV
Posted by Luminar on October 22, 2012 at 9:40 AM
  This message has been viewed 208 times.
In Reply To Re: Would that not be from oil being sucked up by the PCV posted by MaxxAction on October 21, 2012 at 07:54 PM
Message I have the same issue as this guy, just not nearly as bad. But I'm curious as to how the oil ring can be letting oil through the compression rings (that seal the piston to the combustion chamber) and not show low or decreased compression?
Will a leakdown test confirm this? I dont blow ANY smoke even under boost (except the normal puff of black right before full spool)
