TwinTurbo.NET: Nissan 300ZX forum - Was the engine warm when you checked the timing. (n/m)
michaell32 (FL)
on October 17, 2012 at 5:59 PM
Concern on recent 120k job done. Checking my timing
posted by elcid
on October 17, 2012 at 05:54 PM
elcid
17:54:38 10/17/12
Was the engine warm when you checked the timing. (n/m) -
michaell32 (FL)
17:59:25 10/17/12
Re: Concern on recent 120k job done. Checking my timing
elcid
18:14:31 10/17/12
Might be a bad CAS or something else feeding into the timing
ZXoltan
18:16:09 10/17/12
Re: Might be a bad CAS or something else feeding into the timing
elcid
18:35:53 10/17/12
what kind of crank pulley are you using? (n/m)
fuzzymonkey
18:17:16 10/17/12
Re: what kind of crank pulley are you using?
elcid
18:36:42 10/17/12
I had the exact same problem you had with my UR pulley
fuzzymonkey
11:57:45 10/18/12
Did you dis-connect the tps or AAC? (n/m)
MeatMan - 604Z.ca -
18:38:37 10/17/12
Re: Did you dis-connect the tps or AAC?
elcid
18:44:31 10/17/12
brian913
07:08:58 10/18/12
Re: Re: Concern on recent 120k job done. Checking my timing
elcid
07:18:56 10/18/12
elcid
08:46:17 10/18/12
