TwinTurbo.NET: Nissan 300ZX forum - Concern on recent 120k job done. Checking my timing
Subject Concern on recent 120k job done. Checking my timing
Posted by elcid on October 17, 2012 at 5:54 PM
  This message has been viewed 240 times.
Message Hey guys.
So as you may be aware, I did my first evern 120k job on my beaterZ ( NA ) and today, I finally went out and purchased a timing gun just to check out the Z and make sure she is good to go.
Well, after arming myself with TT timing gun knowledege, I proceeded to use the round loop found in the PTU. Checked the timing... 25 degrees!. It kinda looked like it was jumping between 20-25. From previous research, I read that if you got some weird readings , to try and use the #1 wire, which I did with similar results. I adjusted the CAS to 15 and again , it looked like it was jumping between 10-17 degrees. Next, I proceeded to fire up my trusy laptop and hooked ConZult and the timing it reported was also jumping quickly between 12-15 degrees.
I dont think its normal. When I did my belt and counted the cogs, etc...she fires up fine and appears to me that runs fine!. What do you think I should do next?
thanks everyone!
