TwinTurbo.NET: Nissan 300ZX forum - Refill the master cylinder and have a friend pump the brakes
Subject Refill the master cylinder and have a friend pump the brakes
Posted by Under_Powered on October 17, 2012 at 12:38 PM
  This message has been viewed 151 times.
In Reply To brakes completely died while driving -need help in diagnosi posted by auclutch on October 17, 2012 at 01:56 AM
Message while you perform a visual inspection for leaks starting at the reservoir, and working your way to each brake line/caliper, as needed. Should be obvious where the leak is very quickly. I just replaced my master cylinder a month or so ago, pretty simple job.
Everything I need to know about life I learned from TT.net
