TwinTurbo.NET: Nissan 300ZX forum - so...anyone actually change out the engine mounts
Subject so...anyone actually change out the engine mounts
Posted by genic on October 16, 2012 at 7:47 PM
  This message has been viewed 277 times.
Message WITHOUT taking the engine out? ... kinda like taking current mounts (stock) ... loosen them up, raise the engine up with an engine hoist...remove the stock mounts, and put in different ones.
reason being is that i would be going my solid aluminium ones from IPP (one off's) ..they are like the bde mounts without the rubber isolation. just a solid chunk of cnc'd aluminium shaved into a round mount.
OR should i wait until i switch the clutch out this coming spring?
i honestly dont think it would be 'that' hard to loosen the stock mounts up, raise the engine, and slide in the solid ones...but what are your opinions. its not like i would be trying to pull my heads like a doucher with the engine in. (shazzzaaam..had to)
