TwinTurbo.NET: Nissan 300ZX forum - Is it a TT swap by chance?
Subject Is it a TT swap by chance?
Posted by Poppe on October 16, 2012 at 6:28 AM
  This message has been viewed 123 times.
In Reply To Awful grinding noise posted by GrimKreeper on October 15, 2012 at 11:35 AM
Message Using a TT flywheel on an NA tranny requires a shim so that the starter doesn't continue to contact the flywheel.
It could also be that the starter isn't disengaging after starting the car, either because of electrical or mechanical (too gunked up to release) failure.
I'll hope it's the starter for your sake, otherwise you'll have to pull the transmission.
Easiest way to check is to pull the two bolts off of the starter and then turn the crank by hand. See if you hear grinding.
