TwinTurbo.NET: Nissan 300ZX forum - I like cjw3's answer. Remove the CaS turn the key on and
Subject I like cjw3's answer. Remove the CaS turn the key on and
Posted by Supermario680 (WI) on October 16, 2012 at 5:14 AM
  This message has been viewed 184 times.
In Reply To Re: Engine won't start. Backfires. posted by Cjw3 on October 15, 2012 at 09:07 PM
Message Turn the shaft on the CAS. This will trigger fuel and spark. Then lay out all the coils and ground the plugs on the plenum (away from fuel lines..) and visually check for spark in order. Front left front right middle left middle right, back left back right etc...
Some with the injectors, just listen for thvclicks though.
It could also be a poor spark causing excess fuel to build up and sporadically burn off when the spark is lit.
Remove the CaS, turn the key On
