TwinTurbo.NET: Nissan 300ZX forum - Engine won't start. Backfires.
Subject Engine won't start. Backfires.
Posted by 300ZXpert (someday) on October 15, 2012 at 8:23 PM
  This message has been viewed 407 times.
Message Long story short, I purchased a roller Z a few years back which came with an engine that I am only now getting around to trying to start.
The engine will turn over however about all I get is a lot of backfiring. It occurs about every second depending on where I set the cas. Adjusting the cas also seems to affect how hard it backfires.
I realize this sounds like an obvious timing issue however I have verified the following:
- timing is on
- ptu ohms out ok
- injectors ohm out ok
- all plugs spark when spinning cas
- all injectors click when spinning cas
- compression is decent across the board although a few cylinders take many cranks before the compression gauge stops moving (I assume due to leak down issues/blow by).
Things I haven't tested:
- firing order
- clogged injectors
- leaky injectors
- fuel pressure
- valves seating/bent (no idea how to test this)
I've not yet had the time to run these tests as I can only work on the car on the weekend. My main reason for posting is to get some feedback/ideas so I can utilize my time wisely this coming weekend as well as get some parts on order if needed.
Thanks in advance for any help.
