TwinTurbo.NET: Nissan 300ZX forum - Why not replace w/ OEM? Either used or new?
Subject Why not replace w/ OEM? Either used or new?
Posted by Gordo 93TT Daytona on October 15, 2012 at 3:36 PM
  This message has been viewed 160 times.
In Reply To Recommendations needed: Upper control arms and tension rods posted by Mikester(Seattle) on October 15, 2012 at 02:13 PM
Message If you choose to go with aftermarket parts, almost all of which use spherical bearings, you will be introducing a significant higher level of noise, vibration, and impact harshness into the cabin. If you want extra firmness, use OEM parts retrofitted w/ urethane bushings. If you are correcting for camber, then go with the 300 Degree Camber Kit.
If you are not tracking the car, IMO rod end, hard point, aftermarket parts are overkill with unwanted side effects.
_________________________________________________
