TwinTurbo.NET: Nissan 300ZX forum - Re: Re: CAS Signal
Subject Re: Re: CAS Signal
Posted by Cjw3 on October 15, 2012 at 1:11 PM
  This message has been viewed 180 times.
In Reply To Re: CAS Signal posted by daygobaker on October 14, 2012 at 09:35 PM
Message I went a little overboard on my 'Logging Crank Sensor'.. I installed a Sensor from my '01 Toyota Fourcylinder, and cut 36-2 target marks on the crank.. You can see the two missing teeth at TDC.. the two cut at the Next Grove over are for Ballance
With this I can log independiant of the ECU's abilities, and use the Innovate Motorsports SSI-4 and LC-1 to get AFR's Ignition Advance, RPM, TPS and Air Flow..
I have the Same Set up on my Toyota, and the only thing I'll have to change is the Target relationship to TDC..
( I have yet to stuff the motor in the Z.. This work thing is getting in the way of my Fun.. )
Cj
