TwinTurbo.NET: Nissan 300ZX forum - You don't need a manual ECU. an auto ECU will work fine.
Subject You don't need a manual ECU. an auto ECU will work fine.
Posted by Supermario680 (WI) on October 14, 2012 at 8:39 PM
  This message has been viewed 217 times.
In Reply To z not running right? posted by Zinprogress on October 14, 2012 at 12:53 AM
Message And even if you were... You would replace the eeprom, not an injector driver.
You need to make SURE you have no leaks. Not, "I think the leaks are plugged...."
Do a legit boost leak test, do a power balance test to make sure all cylinders are forum and check your ECU codes.
