TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Would leaking TB seals cause failing boost leak test?
smartone
on October 14, 2012 at 1:14 AM
posted by ZBOOSTT
on October 14, 2012 at 12:48 AM
I'm using a boost leak tester, so at the airfilters! And I'm talking about the seals on the sides of the tb's, where the tps is for example.
smartone
21:48:16 10/13/12
ZBOOSTT
00:48:06 10/14/12
Re: Re: Would leaking TB seals cause failing boost leak test? -
smartone
01:14:25 10/14/12
I've never understood why people say only 5 psi....
Supermario680 (WI)
06:16:49 10/14/12
I am thinking the gauge is broken but not 100% sure yet.. (n/m)
smartone
09:53:14 10/14/12
Here:
Summeronthechain (MN)
10:12:00 10/14/12
Find a way to verify that gauge is working first.
Evan_Wright (Ca)
10:00:08 10/14/12
Also, a leak at the tb shaft should be fixed if possible but
Evan_Wright (Ca)
10:02:46 10/14/12
