TwinTurbo.NET: Nissan 300ZX forum - Re: Would leaking TB seals cause failing boost leak test?
Subject Re: Would leaking TB seals cause failing boost leak test?
Posted by ZBOOSTT on October 14, 2012 at 12:48 AM
  This message has been viewed 238 times.
In Reply To Would leaking TB seals cause failing boost leak test? posted by smartone on October 13, 2012 at 09:48 PM
Message TB's do not seal 100% at the butterfly flap. The intake hoses hold the pressure, and the TB gaskets. Be careful not to pump more than 5psi or you may blow seals. Are you adding pressure into the main intake, where the air filter would be?
