TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Probably because the MOST common installation is on the back
Subject Re: Re: Probably because the MOST common installation is on the back
Posted by ZBOOSTT on October 13, 2012 at 10:33 PM
  This message has been viewed 194 times.
In Reply To Re: Probably because the MOST common installation is on the back posted by KA8 on October 13, 2012 at 09:11 PM
Message The bolt should contact the block for it to safely sense knock. Sucks that it is so hard to get in the stock position. I did see a specific bolt size years ago that supposedly just touched the block through the rear plenum bolt. It would have to be a perfect size so the sensor would be tight AND the bolt touching the block. Good luck. Z's are a PITA!
