TwinTurbo.NET: Nissan 300ZX forum - Engine Cont Fuse
Subject Engine Cont Fuse
Posted by zman03 on October 12, 2012 at 1:06 AM
  This message has been viewed 781 times.
Message Stands for engine control fuse. I had this fuse blow on me unknowingly. It caused the engine to run rough and not hold an idle. It also caused the Hicas light, brake light and Lamp Check lights to illuminate in the instrument cluster. Seems there is a sneak circuit somewhere to the lamp check relay circuit when this fuse blows. The fuse controls many engine control components to include:
O2 Sensors heaters
FICD Solenoid
L and R waste gate valve control
AIV control valve solenoid
AAC control solenoid
L and R VTC solenoid
PRVR control solenoid
EGR control solenoid
Another interesting note for this problem is that the ECU did not report any codes when this fuse blew open.
I hope this info helps someone else who has this problem because it isn't obvious what the cause is based on the symptoms. Still not sure why the fuse blew in the first place but most likely one of the above components is going borderline with low resistance.
