TwinTurbo.NET: Nissan 300ZX forum - In a nutshell...
Subject In a nutshell...
Posted by Ted (92TT) on October 08, 2012 at 11:12 AM
  This message has been viewed 192 times.
In Reply To Looking to replace fuel injectors on my 91 TT posted by trusio on October 07, 2012 at 12:22 AM
Message Original eary-style injectors ('91 included) are highly prone to enthanol-related failure. There are several aftermarket brands, all with their own problems. The Nismo 740cc injectors are extremely reliable, hence everyone's recommendation. You will need a new ECU chip and associated socketing to support the larger injectors. You'll also need an adapter kit to mount the newer-style 740cc injectors. A call to Specialty Z will get you everything you need, including trustworthy advice. This solution will cost you more up-front, but is the least costly in the long run, and supports future mods. Replacing with stock 370cc injectors will just extend your cost incrementally and never solve the root problem.
Ted
