TwinTurbo.NET: Nissan 300ZX forum - Look at these links
Subject Look at these links
Posted by Supermario680 (WI) on October 08, 2012 at 6:39 AM
  This message has been viewed 135 times.
In Reply To have notice boost not functioning.. what to do ? thanks posted by BlackTwins on October 07, 2012 at 01:31 AM
Message Check your ECU codes #1 but it sounds like a vacuum/boost leak possibly combined with an alternator issue possibly.
ECU codes - [ http://forums.nicoclub.com/300zx-z32-ecu-diagnostic-t249406.html ]
Boost leak tester to check for leaks, but if its serious enough to cause idle problems it probably isn't too hard to find - [ http://boostpro.net/prodtester.html ]
Also get a Volt meter, start your car, and make sure the battery reads around 14 volts with the engine running.
