TwinTurbo.NET: Nissan 300ZX forum - CAS=crank angle sensor or crank position sensor
Subject CAS=crank angle sensor or crank position sensor
Posted by SMAZ (OKC) on October 07, 2012 at 8:22 PM
  This message has been viewed 710 times.
In Reply To Re: Check the CAS bearing posted by trusio on October 07, 2012 at 06:51 PM
Message If you're facing the engine, it's the big silver aluminum bodied piece on the driver side exhaust cam (the farthest to the right). There are 3 screws that hold it in and it's also what you use to set your base timing. If you remove it, make sure and paint the screw heads or be prepared to reset the timing with a light. As others said, check all connections first.
1996 TT #61 of 300
